Hi Ti,
The LM4875 datasheet describes Input Capacitor.
What is the best type of Capacitor?
Ceramic, multilayer ceramic, film, voltage, etc.
best regards
Hi Ti,
best regards
Hi Atsuo,
Ceramic / MLCC are the most commonly used caps for this purpose. Usually, you select a non-polarized type of cap for this purpose.
-Ivan Salazar
Applications Engineer
Thank you for your prompt reply.
Are there any recommended specifications for Ceramic / MLCC?
Temperature characteristics, rated voltage, etc.
best regards
Hi Atsuo,
X7R or X5R are usually best. Voltage rating should allow some headroom on top of the intended application requirement, eg. if the signal Vpk is 5V you may use 15V rated caps. Special consideration is needed whenever DC voltage is applied to the capacitor, as the capacitance derated considerably in ceramic caps as DC is applied to it.
-Ivan Salazar
Thank you for your response.
I understand the selection specification.
Thank you very much.
