Part Number: TAD5242
Other Parts Discussed in Thread: TAD5212, PCM5242,
Hi team,
I have two questions.
1. THD+N curve
Below is the THD+N curve in differential config with 1.2kOhm impedance attached. You can see the increasing THD+N for higher imput amplitudes.
Is there a way to improve this performance? What happens if you limit the current draw from the dac. for example, higher impedance.
2. Sample silicon vs RTM silicon
I know there was some improvements with sample die vs RTM.
Was pop noise one of the improvements? There was a claim in pop noise in early samples.
Luke
