TLV320ADC6120: What is the algorithm for the I2C checksum value?
Part Number: TLV320ADC6120
I am trying to check if the I2C configuration of the ADC is correct by reading out the checksum value. I can read the value without problem following the documentation of the ADC, however, the documentation does not describe, what algorithm is used to create the checksum value.
Where can I find the algorithm, to decode the checksum value?
Thanks!
  • Hi Gergley,
    Let me get back to you on this thread with an update by the end of this week.
    Thanks and Regards,
    Lakhsmi Narasimhan
  • Hi Gergely,
    The I2C Checksum works as follows:
    1) Consider the current value of the checksum register (B0_P0_R126) be I2C_CKSUM[7:0], an 8-bit value.
    2) If we are writing a value reg_data[7:0] into any register, the checksum updates to a value I2C_CKSUM_NEW[7:0] as follows:
    I2C_CKSUM_NEW[7] = I2C_CKSUM[5] ^ I2C_CKSUM[6] ^ I2C_CKSUM[7] ^ reg_data[5] ^ reg_data[6] ^ reg_data[7]
    I2C_CKSUM_NEW[6] = I2C_CKSUM[4] ^ I2C_CKSUM[5] ^ I2C_CKSUM[6] ^ reg_data[4] ^ reg_data[5] ^ reg_data[6]
    I2C_CKSUM_NEW[5] = I2C_CKSUM[3] ^ I2C_CKSUM[4] ^ I2C_CKSUM[5] ^ reg_data[3] ^ reg_data[4] ^ reg_data[5]
    I2C_CKSUM_NEW[4] = I2C_CKSUM[2] ^ I2C_CKSUM[3] ^ I2C_CKSUM[4] ^ reg_data[2] ^ reg_data[3] ^ reg_data[4]
    I2C_CKSUM_NEW[3] = I2C_CKSUM[1] ^ I2C_CKSUM[2] ^ I2C_CKSUM[3] ^ I2C_CKSUM[7] ^ reg_data[1] ^ reg_data[2] ^ reg_data[3] ^ reg_data[7]
    I2C_CKSUM_NEW[2] = I2C_CKSUM[0] ^ I2C_CKSUM[1] ^ I2C_CKSUM[2] ^ I2C_CKSUM[6] ^ reg_data[0] ^ reg_data[1] ^ reg_data[2] ^ reg_data[6]
    I2C_CKSUM_NEW[1] = I2C_CKSUM[0] ^ I2C_CKSUM[1] ^ I2C_CKSUM[6] ^ reg_data[0] ^ reg_data[1] ^ reg_data[6]
    I2C_CKSUM_NEW[0] = I2C_CKSUM[0] ^ I2C_CKSUM[6] ^ I2C_CKSUM[7] ^ reg_data[0] ^ reg_data[6] ^ reg_data[7]
    with ^ indicating bitwise XOR operation.
    The following register is not considered in this checksum computation:
    Register 0 of all pages, which is the page switch register
    When a SW/HW reset is done, the I2C_CKSUM register reverts to a default value of 0x00
    Thanks and Regards,
    Lakhsmi Narasimhan
  • Hi Lakhsmi,
    Thank you for your answer. I tried it out, and it works.
    Gergely Kiss
