PCM2903C: Can PCM2903C be used for I2S > USB audio interface?
Part Number: PCM2903C
Other Parts Discussed in Thread: PCM2906C, PCM2912A, PCM2903, PCM2903EVM-U
Hello guys,
One of my customers is considering using PCM2903C or PCM2906C for their new products.
At this moment, they has the following questions.
Could you please give me your reply?
Q1.
They are looking for an IC to convert stereo audio to USB audio.
They think the following TI part numbers might be suitable.
・PCM2903C
・PCM2906C
They think the above part numbers are ICs capable of converting stereo audio to USB_IF.
Is their thought correct?
Q2.
If TI has an IC capable of I2S → USB_IF conversion, could you please introduce it?
If I2S → USB_IF conversion is possible, they would like it to support a Master Clock of
11.2896MHz and a sampling rate of 44.1KHz.
They are also considering the product at the following URL as the USB dongle to connect to.
https://www.amazon.co.uk/eppfun-APTX-Adaptive-Transmitter-Compatible-Simultaneously-Black/dp/B0CWXFH1ZF
Your reply would be much appreciated.
Kazuya.
