When the PA switch of the power amplifier is switched, due to the discontinuous signal, the speaker emits a brief "beep" sound.
This abnormal sound will occur when switching between MUTE and UNMUTE.
There is another abnormal sound situation: first, disconnect the four signals MCLK, SCLK, FSYNC, and SDATA (power remains on, the above four signals remain at a high level, MUTE starts), and then reconnect these four signals (power remains on, the above four signals start synchronously, UNMUTE). During this operation, abnormal sounds will occur.
All hardware power supplies, signal timing sequences and signal voltages are normal.
How can this kind of noise be solved?thanks
