Part Number: TLV320AIC3100
Other Parts Discussed in Thread: TLV9162,
The datasheet for the AIC3100 suggests sending differenmtial audio to the device.
Without increasing component count, would it be better to use 1/2 of the TLC9162 as a buffer for Vcc/2 or as an inverter to be able to send differential audio?
The distance from the analog preamp to the AIC3100 is only 3 inches and the (single ended) audio is being routed near the board edge, surrounded by ground plane.
Also, I am looking for recommendations on improving the pcb layout of this device.
I am using 4 layers with a ground plane on layer 2 and power planes on layer 3
Is it really necessary to split the ground plane?
