TAS5828M: Using the DSP for audio delay.
Part Number: TAS5828M
Hi
Is it possible to use the TAS5828M DSP to achieve per channel delay for speaker alignment? I see that the Class-H section has a channel delay time setting, but I don't need the Class-H functionality. Do I just not select a gpio for class H output? What else do I need to set up? I'm currently using 1SPW modulation.
How to achieve more than 240 samples of delay in PBTL?
Also, could you explain the difference between Class-H and hybrid modulation as the datasheet sounds like it is the same thing?
Thank you.
