Part Number: TAA5242
Our customer needs to know MICBIAS and VREF PSRR performance in 1.8VAVDD. Could you please show us these PSRR reference data if you have.
Hi Imi-san,
We don't have a specification on MICBIAS/VREF PSRR in the datasheet of the TAA5242.
Let me check on this further and get back to you by next week.
Thanks and Regards,
Lakshmi Narasimhan
Hi Lakshmi-san,
Could you please let us know the PSRR performance.
Hi Imi-san,
We don't have specifications for the PSRR numbers you have requested, so I would need to measure them on a few devices.
Just to confirm the requirements before measuring, we need the PSRR from AVDD to the VREF/MICBIAS outputs at 1.8V AVDD condition, is that correct?
Thanks and Regards,
Lakshmi Narasimhan
Hi Lakshmi-san,
We checked with the customer about the test condition.
Yes. our customer requests 1.8V AVDD to VREF/MICBIAS PSRR data.
Hi Imi-san,
Thank you for the confirmation.
I can do the measurement on a few devices and get back to you with the measured values by the end of this week.
Thanks and Regards,
Lakshmi Narasimhan
Hi Lakshmi-san,
Thank you very much for your help!! I understood.
You're welcome Imi-san.
I will post an update on this thread by end of this week, as mentioned earlier.
Thanks and Regards,
Lakshmi Narasimhan
Hi Imi-san,
The AVDD-to-MICBIAS PSRR at 1.8V AVDD is ~112dB for a 100mVpk-pk, 1kHz ripple on the AVDD supply.
Thanks and Regards,
Lakshmi Narasimhan
Hi Lakshmi-san,
I understood AVDD to MICBIAS PSRR at 1.8V AVDD is 112dB at 1kHz/100mVpp on AVDD. Could you let us know AVDD to VREF PSRR ?
best regards,
Hi Imi-san,
In TAA5242, the MICBIAS voltage is derived from the VREF voltage, hence the power-supply ripple component seen on MICBIAS output also accounts for any PSRR component on the VREF output.
The VREF PSRR hence is better than the 112dB seen on MICBIAS output.
Thanks and Regards,
Lakshmi Narasimhan
Hi Lakshmi-san,
Thank you very much. Your suggestion resolved customer issue.
