Part Number: TAS3251
I'm looking at TAS3251 Process flows document. Process flow 5 and 6 have these register: Sub Mix ScratchL and Sub Mix ScratchR. What do they do?
Sia
Sia
Hi Sia,
The Sub Mix ScratchL and Sub Mix ScratchR registers can be used to adjust the cut off frequency of the Bass Mono Mixer available in the Stereo 2.2 (Woofer/Tweeter) config.
Sebastian
Hi Sebastian,
Hmm, that doesn't sound right, for the following reasons:
Are you sure that setting the cut off frequency is their function?
Sia
Hi Sia,
I'm trying to find more detailed documentation surrounding these registers, I will get back to you when I find this.
Whenever I adjust the cut off frequency of the bass mono mix in PPC3 it writes to the sub mix scratchL/R registers. That is not their sole function, when I adjust the cut off frequency PPC3 also writes to the bass mono mixer registers on page 0x11 and 0x12 you mentioned.
The bass mono mix feature in PPC3 is only available in the 2.2 Woofer/Tweeter config, so I'm assuming the difference in the default values of the register is related to a woofer/tweeter configuration.
Sebastian
Hi Sebastian,
Thanks for following up. Did you figure this out?
(unfortunately for reasons that I don't understand my access to PPC3 was denied. Otherwise I would figure this out myself and not bother you with these questions.)
Sia
Hi Sia,
I reached out to our design team but this part is quite old so there aren't any designers still around from the development of this part and I can't find further documentation on those registers. So far I have identified the bass mono mix writes to the scratchR/L registers, but I can't tell you what their sole function is yet.
Regarding the PPC3 access, if you used a personal email this is likely why it got rejected. If you can share your end equipment/application we should be able to get you access.
Sebastian
Hi Sebastian,
Ok, my end application is for studio monitors / desktop speakers, essentially consumer electronics.
Sia
Hi Sia,
Our marketing team should have approved you to download PPC3. Let me know if you're still having issues downloading it.
Sebastian
