TPS1H100-Q1: Reverse Current
Part Number: TPS1H100-Q1
Dear Technical Support Team,
Under the condition shown in Fig. 7 of the datasheet, when the device is reverse-connected, could you please advise how many amperes for how many seconds would cause the IC to fail?
The datasheet indicates Irev2 as typ. 2A for t < 60s. If the duration increases, does this current value decrease accordingly?
If so, is there any guideline or reference such as “X amperes for Y seconds”?
Additionally, if you have any characteristic information regarding the channel temperature or other thermal properties of the FET’s body diode, we would greatly appreciate your guidance.
Komatsuda
  • Hi Komatsuda,
    we don't spec for other conditions outside of the ones specified in the data sheet, so make sure to stay within the 2A for < 60s
    we also don't characterize the body diode of the mosfet but it won't be damaged if you stay within the data sheet limits
    Nicholas Petersilge
