Part Number: TAS5805M
Other Parts Discussed in Thread: TAS5805
Hi Team,
Customer wants to use 4pcs TAS5805 in TDM configuration, can you help to check how we can connect the SDOUT pin? Is it correct for below configuration?
Will these devices be configured on different I2S input slots? Or will they be configured to the same slot?
Sydney Northcutt
These devices will be configured on different TDM slots, we know that for SDIN of TAS5805, it can work per datasheet comments. But we are not sure for SDOUT of TAS5805, if it is can be configured as TDM slots as same as SDIN, and with Hi-Z output for TDM application.
Yes this configuration will work. The pins just need to be placed into open drain mode.
Sydney Northcutt
