Part Number: LM4950
I am writeing in regards to the LM4950 Class AB audio amplifier.
I want to use a 4 OHM speaker in BTL configuration. In all examples such loads are single ended.
Is is possivle to use 4 OHM in BTL and potencialy not use the largest gain setting?
The reason why i want to use BTL is so that i would get lower distorsions useing the same available power rails.
If needed i can also add some series resistors.
Bestreagrds,
Robert
