Part Number: PCM1809
Hi team,
The recommended input impedance is approximately 10 k ohm, but are there any guidelines regarding the minimum and maximum values?
Ryu.
Hi team,
Ryu.
Hi Yamashita-san,
The datasheet refers to the internal input impedance of the PCM1809 having a typical value of around 10kOhm.
Thanks and Regards,
Lakshmi Narasimhan
Hi Lakshmi-san,
I understand that.
Because the audio signal level fluctuates depending on the input impedance value, I want to confirm whether that fluctuation falls within the acceptable range for input impedance.
Therefore, I would appreciate it if you could provide me with a rough estimate of the minimum and maximum values for the input impedance.
Ryu.
Hi Yamashita-san,
The impedance can have a variation of around +/-20%.
Thanks and Regards,
Lakshmi Narasimhan
