Part Number: TLV320AIC3268
I am currently working with the TLV320AIC3268 using analog routing (not MiniDSP yet). I would appreciate your guidance regarding startup pop noise and GPS related interference issues.
Current Configuration
Inputs:
IN2 (SkyVoice, also carries GPS data via RS232 in the same system)
IN3 (AoA source)
ASI2 (Bluetooth I2S input)
Routing:
All three signals are mixed using analog routing.
IN2 and IN3 are routed through LPGA.
ASI2 is routed through DAC.
Final mix output goes to LOL/LOR, then to an external Class-D amplifier and 8 ohm speaker.
Parallel outputs are taken from:
RECP/RECM (differential output)
HPL (used as single ended and differential feed to headphone amplifier)
Issues Observed
Startup Pop and Hissing Noise
On power up, there is a noticeable pop followed by hissing noise from the speaker.
The noise persists for a short duration before stabilizing.
GPS / RS232 Data Interference
One of the analog input sources shares the system with a GPS module transmitting RS232 data.
When GPS data is actively streaming, audible digital noise is introduced into the mixed audio output.
Attempted Mitigation
I mixed IN2L and IN3L together.
I tied IN2R and IN3R to CM1 to avoid floating negative inputs.
This reduced the noise significantly.
However, IN3 output became completely silent after this change.
Questions
Is there any firmware level configuration (register settings) to:
Reduce startup pop and hiss?
Improve rejection of digital noise coupling into analog inputs?
Properly configure unused negative inputs without muting the channel?
Are there recommended LPGA, input common mode, biasing, or soft start register settings to reduce pop noise during power up?
Is there a recommended way to configure pseudo differential versus single ended inputs in this case to improve noise immunity without external hardware changes?
Would enabling internal input impedance changes, CM routing, or digital soft stepping help reduce the interference?
At this stage, I am trying to avoid hardware modifications and would like to explore all possible firmware level optimizations first.
Looking forward to your guidance.
Nikhil
