PCM5310 VCOMAD VCOMDA current capabilities?
Other Parts Discussed in Thread: PCM5310
Are the VCOMAD, VCOMDA, VREFAD1 all 1/2 power supply outputs (or are they inputs)?
If they are outputs, what are their driving strength in mA?
I'm using single supply OPAMp I/O circuit, so may I connect VCOMAD, VCOMDA, VREFAD1 together and use them on OP-Amp as common voltage) or if they are inputs what are their input currents demands?
Is there any example schematic for PCM5310 usage? (I was using PCM3052 before and it was all stated clear in datasheet...)
Best regards, Darko
