Part Number: TAS2563
Other Parts Discussed in Thread: TAS5805M, TAS5805
Dear TI Engineer,
Can you help confirm if TAS2563 can support Echo Cancellation function? From the datasheet we can see that it has two SDOUT pin, and this pin can be used as an Echo Cancellation function pin in the pin definition of TAS5805M.
If it support the Echo Cancellation function, how should it be designed? If not supported, can you recommend a small-sized part number with a similar performance parameters to TAS2563.
Kind Regards
