Part Number: TPA3130D2EVM
TPA3130D2EVM used ELDR35C bead seems already EOL.
Would you please help us check below alternative is suitable? thanks!
Jeff
Jeff
Hi Jeff,
it seems that the enclosed beads are similar to the one used on EVM. but the audio THD performance could not be compared as usually it is not listed in the DS. they can be used but please check the audio performance. and meantime, even the bead on EVM is just for reference, it could be changed if there is any EMI issue, the real product may have different EMI performance.
Br,
Wenbin
Hi Jeff,
this depends on the output current of your design. it should be a little more than the max output current.
Br,
Wenbin
