RC4558: Input output range for ±5V supply
Part Number: RC4558
Other Parts Discussed in Thread: RC4580,
Dear Technical Support Team,
Could you share the spec for Input range(VICR) and output range(VOUT ) for ±5V supply?
Datasheet has only ±5V version.
ttd
    We do not have distribution data for these specs at +/-5V to provide a limit.
    The linear operating range for the common mode voltage is 3V inside of each supply rail:
    For the output swing condition you may estimate this from the Maximum Output Voltage Swing vs Operating Voltage below
    Chris Featherstone
  • Hi Chris,
    Thank you for your reply.
    How about RC4580 with ±5V?
    Datahseet does not have test condition with VICR for CMMR.
    but,is it correct to say that, like the RC4558, the linear operating range for the common-mode voltage is within 3 V of each power supply rail?
    ttd
    The common mode range for CMRR is provided in the table in your last reply. This would also be 3V from the supply rail.
    Chris Featherstone
