Part Number: PCM2906C
Other Parts Discussed in Thread: HID2
I'm using the evaluation board (SBAU-195) as a patern for designing a USB audio interface.
Why are HID0, HID1, HID2 pulled up to logic high when internally they are pulled to ground? Why not pull them to ground, or better yet, connect them to ground?
Why are the L+R audio inputs and L+R audio outputs capacitively coupled? The op-amps associated are referenced to "VCOM", a psuedo-ground. There is no voltage across capacitors C108, C109, C101, C102.
Why use an electrolytic capacitor for audio coupling? In time, the electrolytic capacitor fails due to lack of proper bias.
