TAS6584-Q1: Audio amplifier configuration
Part Number: TAS6584-Q1
Hi Expert
We are currently working on an automotive audio amplifier project using the TAS6584-Q1. We are able to observe the BCLK, FSYNC, and SDIN data signals at the amplifier input, indicating that the I2S interface is active. However, we are not getting the expected sine wave output from the amplifier channels.
We have completed the amplifier configuration through I2C by referring to the device datasheet and have verified that the required clocks and audio data are present. Despite this, the amplifier output remains inactive.
Could you please assist us by providing the recommended configuration sequence and activation steps required to bring the amplifier into the playback state? Specifically, we would like to understand:
  • The complete initialization sequence after power-up.
  • Registers that must be configured to enable audio playback.
  • Any required state transitions (Sleep, Standby, Active, Play mode, etc.).
  • Required clock and TDM/I2S settings.
  • Any mute, fault-clear, or channel-enable configurations that must be performed before output is enabled.
  • Methods to verify that the device has successfully entered the active playback state.
    Thank you
