Part Number: TAC5142
Hi Experts,
I need help confirming the design below.
Im working on a project where I want to process FM radio audio digitally and mix it with other digital audio sources. To do this, I'm using an Si4703 (FM radio IC) and a TAC5142 (DAC). I want to use the plugged-in IEM/headphone cable as the RF antenna for the radio.
The TAC5142 uses a pseudo-differential output with an external common-mode sense. Normally, I would connect the common-mode sense directly to the GND sleeve of the headphone jack.
However, since I'm using the IEM cable as the RF antenna for the Si4703, I'm not sure how to properly make this connection.
I connect the OUT2M to the Headphone jack sleeve (CN1 pin 1) through a ferrite bead. The Si4703 FMIP pin is also connected to the ferrite bead. This should be correct right?
Thanks!
Marvin
