Other Parts Discussed in Thread: CC8531, AM3703, TPS65930
I'm using the CC8531 headset to transmit data. I can transmit audio from master to slave and from slave to master using 2 other cards and another audio source.
I would like to connect the 2 slaves together using the I2S interface because i need digital data, not analog. My problem is that each slave receive clocks from his own master, so when i connect the 2 slaves together, they are not synchronized and there is not data transmission. Is there a way to modify this using the PurePath Wireless Configurator or do i have to change something directly on the slave cards ?
Thank you for your answer.
Hugo
