I am confused about the definition and relevance of the Manufacturer ID vs the Default Network ID.
I am trying to configure slave units that automatically pair with a master which contains a specific (unique) Manuacturer ID and Product ID. I have found (using the debugger) that one of my cc85xx devices has the unique hardware ID of 0x2000ABCD. I manually set the Product ID of this master to 0x00000001. So I use 0x2000ABCD as the manufacturer ID, and 0x00000001 as the product ID for the pairing filter for all of my slaves. However, if I configure a second network with a different master (with a different unique hardware ID, say 0x2000ABCX) the original slave will not pair with this second master. I must configure the Default Network ID in the slave to match the new master's unique ID before pairing will occur.
My question is......what is the relevance of a unique Manufacturer ID if you must always program slaves to search for a Default Network ID for each new master? It appears that each new master creates a new Manufacturer ID, which is it's unique hardware ID.
Can someone shed some light on this?
