please help to design amp with TAS5613
Other Parts Discussed in Thread: TAS5613, TAS5630
   my project is to design a 5.1 home theater.i am doing this as a hobby.i have a few tas5613 chip laying here and i thought to give it a try instead of traditional AB amplifiers
1)So in datasheet i think i read TAS5613 can be used in single ended mode my setting the mod pins.But there is no schematic example given there.But in datasheet of TAS5630 there is an example schematic. Can i follow that one?
2)i am having 8ohm speakers with me so can 5613 drive 8ohm loads in single ended mode?my supply is 36 volts?what will be the power outputted to 8ohm in single ended mode
3)can i skip the heat sink for the chip in single ended mode?
i plan to use another TAS5613 for my 4ohm sub and (2x8ohm) center channel.
can i draw the schematic and post it here to get reviewed from you.
this is my first class-d design.so there are plenty of confusions
