We have an issue on our board where the AIC3105 is not always getting reset properly. The reset is driven by an MCU and we've had problem with both a "no pull-up" and a "100K pull-up" configuration.
However we noticed that the problem went away when we hooked up the scope probe, so we changed the PCB so the reset is tied to GND via a 1M Ohm resistor and the problem went away.
Can you confirm that this OK?
