configuration issues
We are in the midst of transferring data back and forth working on the configuration and this is what i got when i received it back from the other engineer.
  • Hi Patrick,
    This error message is typically displayed when a device configuration file is not found. The .ppwprj file specifies the location of the .ppwcfg files within the project. If these files are not found this message will show. Open the .ppwprj file in a text editor to see the expected location of the master and slave device configurations and make sure the files are there. If not, they are probably located in another folder. Locate them and paste them into the correct folder. Restart the configurator.
    Best regards
    Kristoffer
