Other Parts Discussed in Thread: OPA1611, LME49990
i am working to design a audio preamp with the lowest THD+N (obviously ;-) ) and look around LME49990 or OPA1611.
Do you think adding a nulling offset topology (voltage divider with a pot) will improve the THD+N or it will only cancel the offset voltage.
Indeed, if my mind is good, there is already a balance current system in the chip. So, ?
Second question about the general topology. I see in the opa1611 datasheet (page 6) that the inverter topotoly is very much better after 3 kHz. How can we explain that ? topogy, resistance source ? Could you suggest something ?
Thank you very much.
Remy.
