Other Parts Discussed in Thread: SRC4392, PCM1792A
I have examined the product data sheet for the SRC4392 Sample Rate Converter used for audio purposes. The literature states that the SRC4392 uses automatic sample rate conversion, but does not detail what the criteria are for this conversion.
As such, i propose to clock the IC at 24.576MHz which is a multiple of 192KHz sampling frequency (128 x fs).
How can the sample rate conversion be set to output 192kHz sampling frequency ?.
If the sample rate conversion (input to output) is automatically determined, can the SRC4392 be configured only to output at 192kHz ?.
I propose to feed the output of the SRC4392 into the TI PCM1792A DAC.
Thanks and Regards,
Richard.
