Dear community,
i am experimenting with PCM5102EVM-U.
The probleme is that the board has no function. No signal comes through the board. It does not start.
If i connect the board with the pc and i start the CodecControll Software i will get the following message: "'149.99998' is not a valid floating point value". Do you have a solution for this problem?
Do you have a step by step tutorial to start the board?
