I am hooking up a op amp for use as a unity gain buffer. The voltage supplies I am using are ground and -28V to cover the possible range of the input signal.
For bypass capacitors, should I just use a bypass cap from the -28V to ground? like a 0.1uf cap?
Thanks!
Mark
