Hello everyone,
I've noticed problems while simulating the bias voltage, if I change the bias resistor value nothing happens because the current between source and source pins is very low, so I can't set the bias current passing thru the output devices, due to the same problem I can't also simulate driver transistors.
I don't know if this is the right forum for this question,
Thank you very much for your help,
Daniel Almeida
