AC coupling the output of a LME49724
Other Parts Discussed in Thread: LME49724
I'm using the typical application circuit in a design, under what conditions do I need to AC couple the output of the LME49724?
  • Hi, Lester,
    The LME49724 is a fully-differential amplifier; I can't think of a reason you'd need to AC-couple the outputs unless you wanted to use it to drive a single-ended output signal. In which case, I'd probably recommend one of our standard op amps.
    -d2
