Hi everyone
I have installed the latest PurePath Studio with the following information
Version 5.95 build 1 revision 25538
Component Library version 6738
I'm using Windows 7 (64 Bit) Service Pack 1
I've tried to generate code from one of the "Sample Process Flows" found on PPS but I got the following errors on output window
Has anyone experienced that kind of problem??
I will be greatful if someone can help me about this problem.
NOTE : I've installed PPS on 4 different computers (Win 7 and Win XP operating systems) and I observed the same "Build Failed" problem
ibrahim
Generating code for base_main_Rate44 .. assembling ...MemoryType usage: miniDSP_A_coeff: 5, miniDSP_A_data: 0, miniDSP_A_instr: 0, miniDSP_A_instr_alloc: 0, miniDSP_A_cycles: 0, miniDSP_A_cycles_alloc: 0,miniDSP_D_coeff: 73, miniDSP_D_data: 165, miniDSP_D_instr: 0, miniDSP_D_instr_alloc: 0, miniDSP_D_cycles: 0, miniDSP_D_cycles_alloc: 0
Assembly failed
Error: aic_gen.asm(2): Incorrectly formed directive
Error: aic_gen.asm(6): Mismatched .codeblock and .endcodeblock directives
Error: aic_gen.asm(45): Incorrectly formed directive
Error: aic_gen.asm(47): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Input left_in I2S_In_1_Ch1DataOut
Error: aic_gen.asm(48): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Input right_in I2S_In_1_Ch2DataOut
Error: aic_gen.asm(49): Mismatched .codeblock and .endcodeblock directives
Error: aic_gen.asm(106): Incorrectly formed directive
Error: aic_gen.asm(108): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_init Mono_Mixer_1_MixGain1 Mono_Mixer_1_MixIn_1
Error: aic_gen.asm(109): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc Mono_Mixer_1_MixGain2 Mono_Mixer_1_MixIn_2
Error: aic_gen.asm(112): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(113): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(115): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - write 0 Mono_Mixer_1_MixedOut
Error: aic_gen.asm(117): Mismatched .codeblock and .endcodeblock directives
Error: aic_gen.asm(394): Incorrectly formed directive
Error: aic_gen.asm(396): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_init One_M2 High_Filter_BIQUADIN_1_D
Error: aic_gen.asm(397): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_init High_Filter_1_N2 High_Filter_x_1(n-2)
Error: aic_gen.asm(398): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_2 High_Filter_1_N1 High_Filter_x_1(n-1)
Error: aic_gen.asm(399): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - write 1 High_Filter_x_1(n)
Error: aic_gen.asm(400): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc High_Filter_1_N0 High_Filter_x_1(n)
Error: aic_gen.asm(401): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_2 High_Filter_1_D1 High_Filter_y_1(n-1)
Error: aic_gen.asm(402): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc High_Filter_1_D2 High_Filter_y_1(n-2)
Error: aic_gen.asm(403): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_init High_Filter_2_N2 High_Filter_x_2(n-2)
Error: aic_gen.asm(404): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_2 High_Filter_2_N1 High_Filter_x_2(n-1)
Error: aic_gen.asm(405): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - ac_rw_ac High_Filter_2_N0 High_Filter_y_1(n)
Error: aic_gen.asm(406): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_2 High_Filter_2_D1 High_Filter_y_2(n-1)
Error: aic_gen.asm(407): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc High_Filter_2_D2 High_Filter_y_2(n-2)
Error: aic_gen.asm(408): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(409): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(411): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - write 0 High_Filter_y_2(n)
Error: aic_gen.asm(412): Mismatched .codeblock and .endcodeblock directives
Error: aic_gen.asm(633): Incorrectly formed directive
Error: aic_gen.asm(635): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_init One_M2 Low_Filter_BIQUADIN_1_D
Error: aic_gen.asm(636): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_init Low_Filter_1_N2 Low_Filter_x_1(n-2)
Error: aic_gen.asm(637): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_2 Low_Filter_1_N1 Low_Filter_x_1(n-1)
Error: aic_gen.asm(638): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - write 1 Low_Filter_x_1(n)
Error: aic_gen.asm(639): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc Low_Filter_1_N0 Low_Filter_x_1(n)
Error: aic_gen.asm(640): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_2 Low_Filter_1_D1 Low_Filter_y_1(n-1)
Error: aic_gen.asm(641): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc Low_Filter_1_D2 Low_Filter_y_1(n-2)
Error: aic_gen.asm(642): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_init Low_Filter_2_N2 Low_Filter_x_2(n-2)
Error: aic_gen.asm(643): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_2 Low_Filter_2_N1 Low_Filter_x_2(n-1)
Error: aic_gen.asm(644): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - ac_rw_ac Low_Filter_2_N0 Low_Filter_y_1(n)
Error: aic_gen.asm(645): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_2 Low_Filter_2_D1 Low_Filter_y_2(n-1)
Error: aic_gen.asm(646): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc Low_Filter_2_D2 Low_Filter_y_2(n-2)
Error: aic_gen.asm(647): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_init Low_Filter_3_N2 Low_Filter_x_3(n-2)
Error: aic_gen.asm(648): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_2 Low_Filter_3_N1 Low_Filter_x_3(n-1)
Error: aic_gen.asm(649): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - ac_rw_ac Low_Filter_3_N0 Low_Filter_y_2(n)
Error: aic_gen.asm(650): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_2 Low_Filter_3_D1 Low_Filter_y_3(n-1)
Error: aic_gen.asm(651): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc Low_Filter_3_D2 Low_Filter_y_3(n-2)
Error: aic_gen.asm(652): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(653): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(655): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - write 0 Low_Filter_y_3(n)
Error: aic_gen.asm(656): Mismatched .codeblock and .endcodeblock directives
Error: aic_gen.asm(830): Incorrectly formed directive
Error: aic_gen.asm(831): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_init Volume_1_volcmd data_one
Error: aic_gen.asm(832): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc Dyn_Mixer_1_Off_Coefval data_one
Error: aic_gen.asm(833): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(834): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - mult MinusOne_M1 0
Error: aic_gen.asm(835): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - jump jmp_sz Dyn_Mixer_1_SD_Positive
Error: aic_gen.asm(836): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(837): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_init Zero data_one
Error: aic_gen.asm(838): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - jump jmp Dyn_Mixer_1_GenerateFilterOutput
Error: aic_gen.asm(839): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs -
Error: aic_gen.asm(839): Incorrectly formed directive : Dyn_Mixer_1_SD_Positive - label cannot be declared outside .codeblock
Error: aic_gen.asm(840): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - mult Dyn_Mixer_1_Gain_Scaler 2
Error: aic_gen.asm(841): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(842): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - mult Dyn_Mixer_1_Gain 1
Error: aic_gen.asm(843): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs -
Error: aic_gen.asm(843): Incorrectly formed directive : Dyn_Mixer_1_GenerateFilterOutput - label cannot be declared outside .codeblock
Error: aic_gen.asm(844): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(845): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_init MinusOne_M1 Dyn_Mixer_1_IN_2
Error: aic_gen.asm(846): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - write 0 Dyn_Mixer_1_High_Gain
Error: aic_gen.asm(847): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - writecoeff Dyn_Mixer_1_High_Gain_Coeff 2
Error: aic_gen.asm(848): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc Dyn_Mixer_1_High_Gain_Coeff Dyn_Mixer_1_IN_2
Error: aic_gen.asm(849): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_init Dyn_Mixer_1_High_Gain_Coeff Dyn_Mixer_1_IN_1
Error: aic_gen.asm(850): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - mult MinusOne_M1 0
Error: aic_gen.asm(851): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - ac_r_ac One_M1 Dyn_Mixer_1_dummy_data
Error: aic_gen.asm(852): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(853): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(854): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - write 0 Dyn_Mixer_1_Out_1
Error: aic_gen.asm(855): Mismatched .codeblock and .endcodeblock directives
Error: aic_gen.asm(976): Incorrectly formed directive
Error: aic_gen.asm(977): Incorrectly formed directive : Volume_1_volumecontrol - label cannot be declared outside .codeblock
Error: aic_gen.asm(977): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs -
Error: aic_gen.asm(978): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_init Volume_1_volcmd data_one
Error: aic_gen.asm(979): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - compare Volume_1_-1_2_22 Volume_1_volcmd(n-1)
Error: aic_gen.asm(980): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc Volume_1_-1_2_22 Volume_1_currentvol(n-1)
Error: aic_gen.asm(982): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - write 1 Volume_1_volcmd(n)
Error: aic_gen.asm(983): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - jump jmp_eq Volume_1_notnewvol
Error: aic_gen.asm(985): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - write -9 Volume_1_volstep(n-1)
Error: aic_gen.asm(986): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(987): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(988): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_init One_M2 Volume_1_currentvol(n-1)
Error: aic_gen.asm(989): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(990): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - jump jmp Volume_1_updateRam1
Error: aic_gen.asm(992): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs -
Error: aic_gen.asm(992): Incorrectly formed directive : Volume_1_notnewvol - label cannot be declared outside .codeblock
Error: aic_gen.asm(993): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_init One_M2 Volume_1_volstep(n-1)
Error: aic_gen.asm(994): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - compare Zero data_one
Error: aic_gen.asm(995): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc One_M2 Volume_1_currentvol(n-1)
Error: aic_gen.asm(996): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - compare Volume_1_-1_2_22 Volume_1_volcmd(n)
Error: aic_gen.asm(997): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - jump jmp_s Volume_1_negativeRamp
Error: aic_gen.asm(998): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - jump jmp_eq Volume_1_updateRam1
Error: aic_gen.asm(999): Incorrectly formed directive : Volume_1_positiveRamp - label cannot be declared outside .codeblock
Error: aic_gen.asm(999): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs -
Error: aic_gen.asm(1000): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - write 1 Volume_1_currentvol(n)
Error: aic_gen.asm(1001): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - jump jmp_l Volume_1_stillRamping
Error: aic_gen.asm(1002): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_init One_M2 Volume_1_volcmd(n)
Error: aic_gen.asm(1003): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(1005): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_init Zero data_one
Error: aic_gen.asm(1006): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - write 1 Volume_1_currentvol(n)
Error: aic_gen.asm(1007): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - writeCoeff Volume_1_volout 2
Error: aic_gen.asm(1008): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - jump jmp Volume_1_outputData
Error: aic_gen.asm(1010): Incorrectly formed directive : Volume_1_negativeRamp - label cannot be declared outside .codeblock
Error: aic_gen.asm(1010): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs -
Error: aic_gen.asm(1011): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(1012): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - write 1 Volume_1_currentvol(n)
Error: aic_gen.asm(1013): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - jump jmp_g Volume_1_stillRamping
Error: aic_gen.asm(1014): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_init One_M2 Volume_1_volcmd(n)
Error: aic_gen.asm(1015): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(1017): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_init Zero data_one
Error: aic_gen.asm(1018): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - write 1 Volume_1_currentvol(n)
Error: aic_gen.asm(1019): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - writeCoeff Volume_1_volout 2
Error: aic_gen.asm(1020): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - jump jmp Volume_1_outputData
Error: aic_gen.asm(1023): Incorrectly formed directive : Volume_1_updateRam1 - label cannot be declared outside .codeblock
Error: aic_gen.asm(1023): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs -
Error: aic_gen.asm(1024): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(1025): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - write 1 Volume_1_currentvol(n)
Error: aic_gen.asm(1026): Incorrectly formed directive : Volume_1_stillRamping - label cannot be declared outside .codeblock
Error: aic_gen.asm(1026): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs -
Error: aic_gen.asm(1027): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - writeCoeff Volume_1_volout 2
Error: aic_gen.asm(1028): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(1029): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(1030): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_init One_M2 Volume_1_volstep(n-1)
Error: aic_gen.asm(1031): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(1032): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(1034): Incorrectly formed directive : Volume_1_outputData - label cannot be declared outside .codeblock
Error: aic_gen.asm(1034): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs -
Error: aic_gen.asm(1035): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - write 1 Volume_1_volstep(n)
Error: aic_gen.asm(1036): Mismatched .codeblock and .endcodeblock directives
Error: aic_gen.asm(1041): Incorrectly formed directive
Error: aic_gen.asm(1042): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_init Volume_1_volout Volume_1_workingval_1
Error: aic_gen.asm(1043): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_init Volume_1_volout data_one
Error: aic_gen.asm(1044): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(1046): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - write 1 Volume_1_workingoutval_1
Error: aic_gen.asm(1047): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - writeCoeff Volume_1_volout_loudness -1
Error: aic_gen.asm(1048): Mismatched .codeblock and .endcodeblock directives
Error: aic_gen.asm(1513): Incorrectly formed directive
Error: aic_gen.asm(1514): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_Init Int8xOut_1_HPF_n1 Int8xOut_1_L(n-1)
Error: aic_gen.asm(1515): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_HPF_d1 Int8xOut_1_LC(n-1)
Error: aic_gen.asm(1516): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_HPF_n0 Int8xOut_1_L(n)
Error: aic_gen.asm(1517): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Out_RAM Right_Out Int8xOut_1_RGY(n+5)
Error: aic_gen.asm(1518): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Out_RAM Left_Out Int8xOut_1_LGY(n+5)
Error: aic_gen.asm(1519): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - writef 0 Int8xOut_1_LC(n)
Error: aic_gen.asm(1520): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_Init Int8xOut_1_D0 Int8xOut_1_LC(n-37)
Error: aic_gen.asm(1521): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D4 Int8xOut_1_LC(n-2)
Error: aic_gen.asm(1522): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Ac_FW_Ac Int8xOut_1_D0 Int8xOut_1_LC(n)
Error: aic_gen.asm(1523): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D4 Int8xOut_1_LC(n-35)
Error: aic_gen.asm(1524): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D8 Int8xOut_1_LC(n-4)
Error: aic_gen.asm(1525): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D8 Int8xOut_1_LC(n-33)
Error: aic_gen.asm(1526): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D12 Int8xOut_1_LC(n-6)
Error: aic_gen.asm(1527): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D12 Int8xOut_1_LC(n-31)
Error: aic_gen.asm(1528): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D24 Int8xOut_1_LC(n-12)
Error: aic_gen.asm(1529): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D24 Int8xOut_1_LC(n-25)
Error: aic_gen.asm(1530): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D16 Int8xOut_1_LC(n-8)
Error: aic_gen.asm(1531): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D16 Int8xOut_1_LC(n-29)
Error: aic_gen.asm(1532): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D20 Int8xOut_1_LC(n-10)
Error: aic_gen.asm(1533): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D20 Int8xOut_1_LC(n-27)
Error: aic_gen.asm(1534): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D28 Int8xOut_1_LC(n-14)
Error: aic_gen.asm(1535): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D28 Int8xOut_1_LC(n-23)
Error: aic_gen.asm(1536): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D32 Int8xOut_1_LC(n-16)
Error: aic_gen.asm(1537): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D32 Int8xOut_1_LC(n-21)
Error: aic_gen.asm(1538): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D2 Int8xOut_1_LC(n-1)
Error: aic_gen.asm(1539): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D2 Int8xOut_1_LC(n-36)
Error: aic_gen.asm(1540): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D18 Int8xOut_1_LC(n-9)
Error: aic_gen.asm(1541): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D18 Int8xOut_1_LC(n-28)
Error: aic_gen.asm(1542): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D10 Int8xOut_1_LC(n-5)
Error: aic_gen.asm(1543): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D10 Int8xOut_1_LC(n-32)
Error: aic_gen.asm(1544): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D26 Int8xOut_1_LC(n-13)
Error: aic_gen.asm(1545): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D26 Int8xOut_1_LC(n-24)
Error: aic_gen.asm(1546): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D14 Int8xOut_1_LC(n-7)
Error: aic_gen.asm(1547): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D14 Int8xOut_1_LC(n-30)
Error: aic_gen.asm(1548): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D6 Int8xOut_1_LC(n-3)
Error: aic_gen.asm(1549): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D6 Int8xOut_1_LC(n-34)
Error: aic_gen.asm(1550): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D22 Int8xOut_1_LC(n-11)
Error: aic_gen.asm(1551): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D22 Int8xOut_1_LC(n-26)
Error: aic_gen.asm(1552): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D30 Int8xOut_1_LC(n-15)
Error: aic_gen.asm(1553): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D30 Int8xOut_1_LC(n-22)
Error: aic_gen.asm(1554): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D34 Int8xOut_1_LC(n-17)
Error: aic_gen.asm(1555): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D34 Int8xOut_1_LC(n-20)
Error: aic_gen.asm(1556): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D36 Int8xOut_1_LC(n-18)
Error: aic_gen.asm(1557): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D36 Int8xOut_1_LC(n-19)
Error: aic_gen.asm(1558): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(1559): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(1560): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Write 0 Int8xOut_1_LD(n)
Error: aic_gen.asm(1561): Mismatched .codeblock and .endcodeblock directives
Error: aic_gen.asm(1563): Incorrectly formed directive
Error: aic_gen.asm(1564): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_Init Int8xOut_1_HPF_n1 Int8xOut_1_R(n-1)
Error: aic_gen.asm(1565): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_HPF_d1 Int8xOut_1_RC(n-1)
Error: aic_gen.asm(1566): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_HPF_n0 Int8xOut_1_R(n)
Error: aic_gen.asm(1567): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_Init Int8xOut_1_D0 Int8xOut_1_RC(n-37)
Error: aic_gen.asm(1568): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D4 Int8xOut_1_RC(n-2)
Error: aic_gen.asm(1569): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Ac_FW_Ac Int8xOut_1_D0 Int8xOut_1_RC(n)
Error: aic_gen.asm(1570): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D4 Int8xOut_1_RC(n-35)
Error: aic_gen.asm(1571): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D8 Int8xOut_1_RC(n-4)
Error: aic_gen.asm(1572): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D8 Int8xOut_1_RC(n-33)
Error: aic_gen.asm(1573): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Out_RAM Right_Out Int8xOut_1_RGY(n+6)
Error: aic_gen.asm(1574): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Out_RAM Left_Out Int8xOut_1_LGY(n+6)
Error: aic_gen.asm(1575): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D12 Int8xOut_1_RC(n-6)
Error: aic_gen.asm(1576): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D12 Int8xOut_1_RC(n-31)
Error: aic_gen.asm(1577): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D24 Int8xOut_1_RC(n-12)
Error: aic_gen.asm(1578): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D24 Int8xOut_1_RC(n-25)
Error: aic_gen.asm(1579): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D16 Int8xOut_1_RC(n-8)
Error: aic_gen.asm(1580): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D16 Int8xOut_1_RC(n-29)
Error: aic_gen.asm(1581): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D20 Int8xOut_1_RC(n-10)
Error: aic_gen.asm(1582): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D20 Int8xOut_1_RC(n-27)
Error: aic_gen.asm(1583): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D28 Int8xOut_1_RC(n-14)
Error: aic_gen.asm(1584): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D28 Int8xOut_1_RC(n-23)
Error: aic_gen.asm(1585): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D32 Int8xOut_1_RC(n-16)
Error: aic_gen.asm(1586): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D32 Int8xOut_1_RC(n-21)
Error: aic_gen.asm(1587): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D2 Int8xOut_1_RC(n-1)
Error: aic_gen.asm(1588): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D2 Int8xOut_1_RC(n-36)
Error: aic_gen.asm(1589): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D18 Int8xOut_1_RC(n-9)
Error: aic_gen.asm(1590): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D18 Int8xOut_1_RC(n-28)
Error: aic_gen.asm(1591): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D10 Int8xOut_1_RC(n-5)
Error: aic_gen.asm(1592): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D10 Int8xOut_1_RC(n-32)
Error: aic_gen.asm(1593): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D26 Int8xOut_1_RC(n-13)
Error: aic_gen.asm(1594): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D26 Int8xOut_1_RC(n-24)
Error: aic_gen.asm(1595): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D14 Int8xOut_1_RC(n-7)
Error: aic_gen.asm(1596): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D14 Int8xOut_1_RC(n-30)
Error: aic_gen.asm(1597): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D6 Int8xOut_1_RC(n-3)
Error: aic_gen.asm(1598): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D6 Int8xOut_1_RC(n-34)
Error: aic_gen.asm(1599): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D22 Int8xOut_1_RC(n-11)
Error: aic_gen.asm(1600): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D22 Int8xOut_1_RC(n-26)
Error: aic_gen.asm(1601): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D30 Int8xOut_1_RC(n-15)
Error: aic_gen.asm(1602): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D30 Int8xOut_1_RC(n-22)
Error: aic_gen.asm(1603): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D34 Int8xOut_1_RC(n-17)
Error: aic_gen.asm(1604): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D34 Int8xOut_1_RC(n-20)
Error: aic_gen.asm(1605): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D36 Int8xOut_1_RC(n-18)
Error: aic_gen.asm(1606): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_D36 Int8xOut_1_RC(n-19)
Error: aic_gen.asm(1607): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_Init Int8xOut_1_E0 Int8xOut_1_RD(n-7)
Error: aic_gen.asm(1608): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_E4 Int8xOut_1_RD(n-2)
Error: aic_gen.asm(1609): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Ac_RW_Ac Int8xOut_1_E0 Int8xOut_1_RD(n)
Error: aic_gen.asm(1610): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_E4 Int8xOut_1_RD(n-5)
Error: aic_gen.asm(1611): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_E6 Int8xOut_1_RD(n-3)
Error: aic_gen.asm(1612): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_E6 Int8xOut_1_RD(n-4)
Error: aic_gen.asm(1613): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_E2 Int8xOut_1_RD(n-1)
Error: aic_gen.asm(1614): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_E2 Int8xOut_1_RD(n-6)
Error: aic_gen.asm(1615): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_Init Int8xOut_1_F2 Int8xOut_1_RE(n-1)
Error: aic_gen.asm(1616): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F2 Int8xOut_1_RE(n-2)
Error: aic_gen.asm(1617): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Ac_RW_Ac Int8xOut_1_F0 Int8xOut_1_RE(n)
Error: aic_gen.asm(1618): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F0 Int8xOut_1_RE(n-3)
Error: aic_gen.asm(1619): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop_1
Error: aic_gen.asm(1620): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - PGAI Gain_R 3
Error: aic_gen.asm(1621): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_Init Int8xOut_1_E0 Int8xOut_1_LD(n-7)
Error: aic_gen.asm(1622): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_E0 Int8xOut_1_LD(n)
Error: aic_gen.asm(1623): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Write 2 Int8xOut_1_RGY(n)
Error: aic_gen.asm(1624): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_E4 Int8xOut_1_LD(n-2)
Error: aic_gen.asm(1625): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_E4 Int8xOut_1_LD(n-5)
Error: aic_gen.asm(1626): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_E6 Int8xOut_1_LD(n-3)
Error: aic_gen.asm(1627): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_E6 Int8xOut_1_LD(n-4)
Error: aic_gen.asm(1628): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_E2 Int8xOut_1_LD(n-1)
Error: aic_gen.asm(1629): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_E2 Int8xOut_1_LD(n-6)
Error: aic_gen.asm(1630): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_Init Int8xOut_1_F2 Int8xOut_1_LE(n-1)
Error: aic_gen.asm(1631): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F2 Int8xOut_1_LE(n-2)
Error: aic_gen.asm(1632): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Ac_RW_Ac Int8xOut_1_F0 Int8xOut_1_LE(n)
Error: aic_gen.asm(1633): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F0 Int8xOut_1_LE(n-3)
Error: aic_gen.asm(1634): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - NOP
Error: aic_gen.asm(1635): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - PGAI Gain_L 3
Error: aic_gen.asm(1636): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(1637): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(1638): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Write 2 Int8xOut_1_LGY(n)
Error: aic_gen.asm(1639): Mismatched .codeblock and .endcodeblock directives
Error: aic_gen.asm(1641): Incorrectly formed directive
Error: aic_gen.asm(1642): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Out_RAM Right_Out Int8xOut_1_RGY(n)
Error: aic_gen.asm(1643): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Out_RAM Left_Out Int8xOut_1_LGY(n)
Error: aic_gen.asm(1644): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_Init Int8xOut_1_F1 Int8xOut_1_RE(n)
Error: aic_gen.asm(1645): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F1 Int8xOut_1_RE(n-2)
Error: aic_gen.asm(1646): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F3 Int8xOut_1_RE(n-1)
Error: aic_gen.asm(1647): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop_1
Error: aic_gen.asm(1648): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - PGAI Gain_R 3
Error: aic_gen.asm(1649): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_Init Int8xOut_1_F1 Int8xOut_1_LE(n)
Error: aic_gen.asm(1650): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F1 Int8xOut_1_LE(n-2)
Error: aic_gen.asm(1651): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Write 2 Int8xOut_1_RGY(n+1)
Error: aic_gen.asm(1652): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F3 Int8xOut_1_LE(n-1)
Error: aic_gen.asm(1653): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Nop
Error: aic_gen.asm(1654): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - PGAI Gain_L 3
Error: aic_gen.asm(1655): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_Init Int8xOut_1_E7 Int8xOut_1_RD(n-3)
Error: aic_gen.asm(1656): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_Init Int8xOut_1_F0 Int8xOut_1_RE(n-2)
Error: aic_gen.asm(1657): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Write 2 Int8xOut_1_LGY(n+1)
Error: aic_gen.asm(1658): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Ac_RW_Ac Int8xOut_1_F0 Int8xOut_1_RE(n+1)
Error: aic_gen.asm(1659): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F2 Int8xOut_1_RE(n)
Error: aic_gen.asm(1660): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F2 Int8xOut_1_RE(n-1)
Error: aic_gen.asm(1661): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Nop_1
Error: aic_gen.asm(1662): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - PGAI Gain_R 3
Error: aic_gen.asm(1663): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_Init Int8xOut_1_E7 Int8xOut_1_LD(n-3)
Error: aic_gen.asm(1664): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_Init Int8xOut_1_F0 Int8xOut_1_LE(n-2)
Error: aic_gen.asm(1665): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Write 2 Int8xOut_1_RGY(n+2)
Error: aic_gen.asm(1666): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Ac_RW_Ac Int8xOut_1_F0 Int8xOut_1_LE(n+1)
Error: aic_gen.asm(1667): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F2 Int8xOut_1_LE(n)
Error: aic_gen.asm(1668): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F2 Int8xOut_1_LE(n-1)
Error: aic_gen.asm(1669): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(1670): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - PGAI Gain_L 3
Error: aic_gen.asm(1671): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_Init Int8xOut_1_F1 Int8xOut_1_RE(n+1)
Error: aic_gen.asm(1672): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F1 Int8xOut_1_RE(n-1)
Error: aic_gen.asm(1673): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Write 2 Int8xOut_1_LGY(n+2)
Error: aic_gen.asm(1674): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F3 Int8xOut_1_RE(n)
Error: aic_gen.asm(1675): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - NOP_1
Error: aic_gen.asm(1676): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - PGAI Gain_R 3
Error: aic_gen.asm(1677): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(1678): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(1680): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Write 2 Int8xOut_1_RGY(n+3)
Error: aic_gen.asm(1681): Mismatched .codeblock and .endcodeblock directives
Error: aic_gen.asm(1683): Incorrectly formed directive
Error: aic_gen.asm(1684): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Out_RAM Right_Out Int8xOut_1_RGY(n+1)
Error: aic_gen.asm(1685): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Out_RAM Left_Out Int8xOut_1_LGY(n+1)
Error: aic_gen.asm(1686): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_Init Int8xOut_1_F1 Int8xOut_1_LE(n+1)
Error: aic_gen.asm(1687): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F1 Int8xOut_1_LE(n-1)
Error: aic_gen.asm(1688): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F3 Int8xOut_1_LE(n)
Error: aic_gen.asm(1689): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Nop
Error: aic_gen.asm(1690): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - PGAI Gain_L 3
Error: aic_gen.asm(1691): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_Init Int8xOut_1_D37 Int8xOut_1_RC(n-18)
Error: aic_gen.asm(1692): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_Init Int8xOut_1_E0 Int8xOut_1_RD(n-6)
Error: aic_gen.asm(1693): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Write 2 Int8xOut_1_LGY(n+3)
Error: aic_gen.asm(1694): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Ac_RW_Ac Int8xOut_1_E0 Int8xOut_1_RD(n+1)
Error: aic_gen.asm(1695): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_E4 Int8xOut_1_RD(n-1)
Error: aic_gen.asm(1696): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_E4 Int8xOut_1_RD(n-4)
Error: aic_gen.asm(1697): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_E6 Int8xOut_1_RD(n-2)
Error: aic_gen.asm(1698): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_E6 Int8xOut_1_RD(n-3)
Error: aic_gen.asm(1699): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_E2 Int8xOut_1_RD(n)
Error: aic_gen.asm(1700): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_E2 Int8xOut_1_RD(n-5)
Error: aic_gen.asm(1701): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_Init Int8xOut_1_F2 Int8xOut_1_RE(n+1)
Error: aic_gen.asm(1702): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F2 Int8xOut_1_RE(n)
Error: aic_gen.asm(1703): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Ac_RW_Ac Int8xOut_1_F0 Int8xOut_1_RE(n+2)
Error: aic_gen.asm(1704): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F0 Int8xOut_1_RE(n-1)
Error: aic_gen.asm(1705): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Nop_1
Error: aic_gen.asm(1706): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - PGAI Gain_R 3
Error: aic_gen.asm(1707): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_Init Int8xOut_1_D37 Int8xOut_1_LC(n-18)
Error: aic_gen.asm(1708): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_Init Int8xOut_1_E0 Int8xOut_1_LD(n-6)
Error: aic_gen.asm(1709): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Write 2 Int8xOut_1_RGY(n+4)
Error: aic_gen.asm(1710): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Ac_RW_Ac Int8xOut_1_E0 Int8xOut_1_LD(n+1)
Error: aic_gen.asm(1711): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_E4 Int8xOut_1_LD(n-1)
Error: aic_gen.asm(1712): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_E4 Int8xOut_1_LD(n-4)
Error: aic_gen.asm(1713): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_E6 Int8xOut_1_LD(n-2)
Error: aic_gen.asm(1714): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_E6 Int8xOut_1_LD(n-3)
Error: aic_gen.asm(1715): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_E2 Int8xOut_1_LD(n)
Error: aic_gen.asm(1716): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_E2 Int8xOut_1_LD(n-5)
Error: aic_gen.asm(1717): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_Init Int8xOut_1_F2 Int8xOut_1_LE(n+1)
Error: aic_gen.asm(1718): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F2 Int8xOut_1_LE(n)
Error: aic_gen.asm(1719): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Ac_RW_Ac Int8xOut_1_F0 Int8xOut_1_LE(n+2)
Error: aic_gen.asm(1720): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F0 Int8xOut_1_LE(n-1)
Error: aic_gen.asm(1721): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(1722): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - PGAI Gain_L 3
Error: aic_gen.asm(1723): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_Init Int8xOut_1_F1 Int8xOut_1_RE(n+2)
Error: aic_gen.asm(1724): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F1 Int8xOut_1_RE(n)
Error: aic_gen.asm(1725): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Write 2 Int8xOut_1_LGY(n+4)
Error: aic_gen.asm(1726): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F3 Int8xOut_1_RE(n+1)
Error: aic_gen.asm(1727): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - NOP_1
Error: aic_gen.asm(1728): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - PGAI Gain_R 3
Error: aic_gen.asm(1729): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(1730): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(1731): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Write 2 Int8xOut_1_RGY(n+5)
Error: aic_gen.asm(1732): Mismatched .codeblock and .endcodeblock directives
Error: aic_gen.asm(1734): Incorrectly formed directive
Error: aic_gen.asm(1735): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Out_RAM Right_Out Int8xOut_1_RGY(n+2)
Error: aic_gen.asm(1736): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Out_RAM Left_Out Int8xOut_1_LGY(n+2)
Error: aic_gen.asm(1737): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_Init Int8xOut_1_F1 Int8xOut_1_LE(n+2)
Error: aic_gen.asm(1738): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F1 Int8xOut_1_LE(n)
Error: aic_gen.asm(1739): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F3 Int8xOut_1_LE(n+1)
Error: aic_gen.asm(1740): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Nop
Error: aic_gen.asm(1741): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - PGAI Gain_L 3
Error: aic_gen.asm(1742): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_Init Int8xOut_1_E7 Int8xOut_1_RD(n-2)
Error: aic_gen.asm(1743): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_Init Int8xOut_1_F0 Int8xOut_1_RE(n)
Error: aic_gen.asm(1744): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Write 2 Int8xOut_1_LGY(n+5)
Error: aic_gen.asm(1745): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Ac_RW_Ac Int8xOut_1_F0 Int8xOut_1_RE(n+3)
Error: aic_gen.asm(1746): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F2 Int8xOut_1_RE(n+2)
Error: aic_gen.asm(1747): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F2 Int8xOut_1_RE(n+1)
Error: aic_gen.asm(1748): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Nop_1
Error: aic_gen.asm(1749): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - PGAI Gain_R 3
Error: aic_gen.asm(1750): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_Init Int8xOut_1_E7 Int8xOut_1_LD(n-2)
Error: aic_gen.asm(1751): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_Init Int8xOut_1_F0 Int8xOut_1_LE(n)
Error: aic_gen.asm(1752): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Write 2 Int8xOut_1_RGY(n+6)
Error: aic_gen.asm(1753): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Ac_RW_Ac Int8xOut_1_F0 Int8xOut_1_LE(n+3)
Error: aic_gen.asm(1754): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F2 Int8xOut_1_LE(n+2)
Error: aic_gen.asm(1755): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F2 Int8xOut_1_LE(n+1)
Error: aic_gen.asm(1756): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(1757): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - PGAI Gain_L 3
Error: aic_gen.asm(1758): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_Init Int8xOut_1_F1 Int8xOut_1_RE(n+3)
Error: aic_gen.asm(1759): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F1 Int8xOut_1_RE(n+1)
Error: aic_gen.asm(1760): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Write 2 Int8xOut_1_LGY(n+6)
Error: aic_gen.asm(1761): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F3 Int8xOut_1_RE(n+2)
Error: aic_gen.asm(1762): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop_1
Error: aic_gen.asm(1763): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - PGAI Gain_R 3
Error: aic_gen.asm(1764): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_Init Int8xOut_1_F1 Int8xOut_1_LE(n+3)
Error: aic_gen.asm(1765): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F1 Int8xOut_1_LE(n+1)
Error: aic_gen.asm(1766): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Write 2 Int8xOut_1_RGY(n+7)
Error: aic_gen.asm(1767): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc Int8xOut_1_F3 Int8xOut_1_LE(n+2)
Error: aic_gen.asm(1768): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - NOP
Error: aic_gen.asm(1769): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - PGAI Gain_L 3
Error: aic_gen.asm(1770): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(1771): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(1773): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Write 2 Int8xOut_1_LGY(n+7)
Error: aic_gen.asm(1774): Mismatched .codeblock and .endcodeblock directives
Error: aic_gen.asm(1776): Incorrectly formed directive
Error: aic_gen.asm(1777): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Out_RAM Right_Out Int8xOut_1_RGY(n+3)
Error: aic_gen.asm(1778): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Out_RAM Left_Out Int8xOut_1_LGY(n+3)
Error: aic_gen.asm(1779): Mismatched .codeblock and .endcodeblock directives
Error: aic_gen.asm(1781): Incorrectly formed directive
Error: aic_gen.asm(1782): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Out_RAM Right_Out Int8xOut_1_RGY(n+4)
Error: aic_gen.asm(1783): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Out_RAM Left_Out Int8xOut_1_LGY(n+4)
Error: aic_gen.asm(1784): Mismatched .codeblock and .endcodeblock directives
Error: aic_gen.asm(1786): Incorrectly formed directive
Error: aic_gen.asm(1787): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_init One_M2 Int8xOut_1_WorkingvalL(n)
Error: aic_gen.asm(1788): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Acc_init One_M2 Int8xOut_1_WorkingvalR(n)
Error: aic_gen.asm(1789): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(1790): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - write 1 Int8xOut_1_L(n+1)
Error: aic_gen.asm(1791): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - write 1 Int8xOut_1_R(n+1)
Error: aic_gen.asm(1792): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Out_RAM Right_Out Int8xOut_1_RGY(n+5)
Error: aic_gen.asm(1793): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - Out_RAM Left_Out Int8xOut_1_LGY(n+5)
Error: aic_gen.asm(1794): Mismatched .codeblock and .endcodeblock directives
Error: aic_gen.asm(3134): Incorrectly formed directive
Error: aic_gen.asm(3138): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - acc_init One_M2 Mix_Hi_Gain_Ch_In_D
Error: aic_gen.asm(3139): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(3140): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - nop
Error: aic_gen.asm(3142): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - writecoeff Mix_Hi_Gain_Coefval 3
Error: aic_gen.asm(3144): Mismatched .codeblock and .endcodeblock directives
Error: aic_main.asm(166): Incorrectly formed directive
Error: aic_main.asm(167): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - jump jmp -1
Error: aic_main.asm(168): Mismatched .codeblock and .endcodeblock directives
Error: aic_main.asm(169): Incorrectly formed directive
Error: aic_main.asm(170): Invalid statement. Must be a directive or comment. Instructions must be within .codeblock constructs - jump jmp -1
Error: aic_main.asm(171): Mismatched .codeblock and .endcodeblock directives
469 errors detected
Assembler was terminated.
Summary: 469 Error(s)
Code generation terminated on base main Rate44
Build failed.
