Issues on getting the capture work in AT91SAMA5D34 using TLV320AIC3106 Codec
Hi experts,
    I'm able to get the playback work with TLV320AIC3x for AT91SAMA5D34
board, but capture seems to be not working on testing with "arecord".The
hw_params for snd-soc are based on this link,
http://mailman.alsa-project.org/pipermail/alsa-devel/2011-March/038253.html
    We would like to know what are the configuration settings required
for TLV320AIC3X. Help us on finding where the issue is lying.
    Please find the attachment for Kernel log, amixer and tlv320aic3x
register settings along with this mail.
root@(none):~# arecord -c 1 -d 10 -r 44100 -f S16_LE -t wav hello.wav
atmel_ssc_startup: SSC_SR=0x0
Recording WAVE 'hello.wav' : Signed 16 bit Little Endian, Rate 44100 Hz, Mono
KDBG: In soc_pcm_hw_params
KDBG: In sama5d3_hw_params
KDBG: Set Codec DAI configuration
KDBG: Set Cpu DAI configuration
KDBG: Audio parameters : rate = ac44 channels = 1 formats= 2
KDBG: Found audio parameters
KDBG: TLV320AIC3X CLKGEN Control Register: 2
KDBG: In aic3x_hw_params
KDBG: tlv320aic3x register values:
KDBG: Audio overflow status & PLL_R programming register 1
KDBG: AIC3X_STICKY_IRQ_FLAGS_REG 0
KDBG: AIC3X_RT_IRQ_FLAGS_REG 0
KDBG: AIC3X_GPIO1_REG 0
KDBG: AIC3X_GPIO2_REG 0
KDBG: AIC3X_GPIOA_REG 0
KDBG: 101-AIC3X_GPIOB_REG 0
KDBG: 102-AIC3X_CLKGEN_CTRL_REG 2
KDBG: 3-AIC3X_PLL_PROGA_REG 91
KDBG: 13-AIC3X_HEADSET_DETECT_CTRL_A 0
KDBG: 14-AIC3X_HEADSET_DETECT_CTRL_B 0
KDBG: ADC PGA control registers ->
KDBG: 15-LADC_VOL 77
KDBG: 16-RADC_VOL 77
KDBG: MIC Control registers
KDBG: 17-MIC3LR_2_LADC_CTRL ff
KDBG: 18-MIC3LR_2_RADC_CTRL ff
KDBG: Line1L Input Control Registers->
KDBG: 19-LINE1L_2_LADC_CTRL 0
KDBG: 21-LINE1R_2_LADC_CTRL 0
KDBG: 22-LINE1R_2_RADC_CTRL 0
KDBG: 24-LINE1L_2_RADC_CTRL 0
KDBG: 25-Mic Bias control MICBIAS_CTRL 0
KDBG: 26-LAGC_CTRL_A 0
KDBG: 36-ADC Flag register 0
KDBG: 108-PASSIVE_BYPASS 11
atmel_ssc_hw_params: RCMR=1a010424 RFMR=001f008f TCMR=1a010404 TFMR=001f008f
atmel_ssc_dai: Starting clock
atmel_ssc_dai,hw_params: SSC initialized
KDBG: In atmel_pcm_hw_params
receive enabled SSC_SR=0x00020c00
^CAbortatmel_ssc_shutdown: receive disabled SSC_SR=0x00020830
eatmel_ssc_dau: Stopping clock
d by signal Interrupt...
root@(none):~# arecord -c 1 -d 10 -r 44100 -vv -f S16_LE -t wav hello1.wav
Recording WAVE 'hello1.wav' : Signed 16 bit Little Endian, Rate 44100 Hz, Mono
Plug PCM: Hardware PCM card 0 'tlv320aic3x @ SAMA5D3' device 0 subdevice 0
Its setup is:
  stream       : CAPTURE
  access       : RW_INTERLEAVED
  format       : S16_LE
  subformat    : STD
  channels     : 1
  rate         : 44100
  exact rate   : 44100 (44100/1)
  msbits       : 16
  buffer_size  : 32768
  period_size  : 4096
  period_time  : 92879
  tstamp_mode  : NONE
  period_step  : 1
  avail_min    : 4096
  period_event : 0
  start_threshold  : 1
  stop_threshold   : 32768
  silence_threshold: 0
  silence_size : 0
  boundary     : 1073741824
  appl_ptr     : 0
  hw_ptr       : 0
#+    atmel_ssc_shutdown: receive disabled SSC_SR=0x00020830
                                            | 00%
 amixer -c 0 contents
numid=1,iface=MIXER,name='PCM Playback Volume'
  ; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
  : values=127,127
  | dBscale-min=-63.50dB,step=0.50dB,mute=0
numid=22,iface=MIXER,name='Line DAC Playback Volume'
  ; type=INTEGER,access=rw---R--,values=2,min=0,max=118,step=0
  : values=71,71
  | dBscale-min=-59.00dB,step=0.50dB,mute=1
numid=20,iface=MIXER,name='Line Line2 Bypass Volume'
  : values=118,118
numid=21,iface=MIXER,name='Line PGA Bypass Volume'
  : values=118,118
numid=32,iface=MIXER,name='Line Playback Switch'
  ; type=BOOLEAN,access=rw------,values=2
  : values=on,on
numid=25,iface=MIXER,name='Mono DAC Playback Volume'
  : values=71,71
numid=23,iface=MIXER,name='Mono Line2 Bypass Volume'
  : values=118,118
numid=73,iface=MIXER,name='Mono Mixer DACL1 Switch'
  ; type=BOOLEAN,access=rw------,values=1
  : values=on
numid=76,iface=MIXER,name='Mono Mixer DACR1 Switch'
  : values=on
numid=71,iface=MIXER,name='Mono Mixer Line2L Bypass Switch'
  : values=off
numid=74,iface=MIXER,name='Mono Mixer Line2R Bypass Switch'
  : values=off
numid=72,iface=MIXER,name='Mono Mixer PGAL Bypass Switch'
  : values=off
numid=75,iface=MIXER,name='Mono Mixer PGAR Bypass Switch'
  : values=off
numid=24,iface=MIXER,name='Mono PGA Bypass Volume'
  : values=118,118
numid=33,iface=MIXER,name='Mono Playback Switch'
  : values=on
numid=46,iface=MIXER,name='ADC HPF Cut-off'
  ; type=ENUMERATED,access=rw------,values=2,items=4
  ; Item #0 'Disabled'
  ; Item #1 '0.0045xFs'
  ; Item #2 '0.0125xFs'
  ; Item #3 '0.025xFs'
  : values=0,0
numid=36,iface=MIXER,name='AGC Switch'
  : values=off,off
numid=43,iface=MIXER,name='De-emphasis Switch'
  : values=off,off
numid=28,iface=MIXER,name='HP DAC Playback Volume'
  : values=71,71
numid=26,iface=MIXER,name='HP Line2 Bypass Volume'
  : values=118,118
numid=27,iface=MIXER,name='HP PGA Bypass Volume'
  : values=118,118
numid=34,iface=MIXER,name='HP Playback Switch'
  : values=on,on
numid=31,iface=MIXER,name='HPCOM DAC Playback Volume'
  : values=71,71
numid=29,iface=MIXER,name='HPCOM Line2 Bypass Volume'
  : values=118,118
numid=30,iface=MIXER,name='HPCOM PGA Bypass Volume'
  : values=118,118
numid=35,iface=MIXER,name='HPCOM Playback Switch'
  : values=on,on
numid=39,iface=MIXER,name='Left AGC Attack time'
  ; type=ENUMERATED,access=rw------,values=1,items=4
  ; Item #0 '8ms'
  ; Item #1 '11ms'
  ; Item #2 '16ms'
  ; Item #3 '20ms'
  : values=0
numid=41,iface=MIXER,name='Left AGC Decay time'
  ; Item #0 '100ms'
  ; Item #1 '200ms'
  ; Item #2 '400ms'
  ; Item #3 '500ms'
  : values=0
numid=37,iface=MIXER,name='Left AGC Target level'
  ; type=ENUMERATED,access=rw------,values=1,items=8
  ; Item #0 '-5.5dB'
  ; Item #1 '-8dB'
  ; Item #2 '-10dB'
  ; Item #3 '-12dB'
  ; Item #4 '-14dB'
  ; Item #5 '-17dB'
  ; Item #6 '-20dB'
  ; Item #7 '-24dB'
  : values=0
numid=108,iface=MIXER,name='Left DAC Mux'
  ; type=ENUMERATED,access=rw------,values=1,items=3
  ; Item #0 'DAC_L1'
  ; Item #1 'DAC_L3'
  ; Item #2 'DAC_L2'
  : values=0
numid=67,iface=MIXER,name='Left HP Mixer DACL1 Switch'
  : values=on
numid=10,iface=MIXER,name='Left HP Mixer DACR1 Playback Volume'
  ; type=INTEGER,access=rw---R--,values=1,min=0,max=118,step=0
  : values=118
numid=70,iface=MIXER,name='Left HP Mixer DACR1 Switch'
  : values=off
numid=65,iface=MIXER,name='Left HP Mixer Line2L Bypass Switch'
  : values=off
numid=68,iface=MIXER,name='Left HP Mixer Line2R Bypass Switch'
  : values=off
numid=8,iface=MIXER,name='Left HP Mixer Line2R Bypass Volume'
  : values=118
numid=66,iface=MIXER,name='Left HP Mixer PGAL Bypass Switch'
  : values=off
numid=69,iface=MIXER,name='Left HP Mixer PGAR Bypass Switch'
  : values=off
numid=9,iface=MIXER,name='Left HP Mixer PGAR Bypass Volume'
  : values=118
numid=55,iface=MIXER,name='Left HPCOM Mixer DACL1 Switch'
  : values=on
numid=16,iface=MIXER,name='Left HPCOM Mixer DACR1 Playback Volume'
  : values=118
numid=58,iface=MIXER,name='Left HPCOM Mixer DACR1 Switch'
  : values=off
numid=53,iface=MIXER,name='Left HPCOM Mixer Line2L Bypass Switch'
  : values=off
numid=56,iface=MIXER,name='Left HPCOM Mixer Line2R Bypass Switch'
  : values=off
numid=14,iface=MIXER,name='Left HPCOM Mixer Line2R Bypass Volume'
  : values=118
numid=54,iface=MIXER,name='Left HPCOM Mixer PGAL Bypass Switch'
  : values=off
numid=57,iface=MIXER,name='Left HPCOM Mixer PGAR Bypass Switch'
  : values=off
numid=15,iface=MIXER,name='Left HPCOM Mixer PGAR Bypass Volume'
  : values=118
numid=107,iface=MIXER,name='Left HPCOM Mux'
  ; Item #0 'differential of HPLOUT'
  ; Item #1 'constant VCM'
  ; Item #2 'single-ended'
  : values=0
numid=85,iface=MIXER,name='Left Line Mixer DACL1 Switch'
  : values=on
numid=4,iface=MIXER,name='Left Line Mixer DACR1 Playback Volume'
  : values=118
numid=88,iface=MIXER,name='Left Line Mixer DACR1 Switch'
  : values=off
numid=83,iface=MIXER,name='Left Line Mixer Line2L Bypass Switch'
  : values=off
numid=86,iface=MIXER,name='Left Line Mixer Line2R Bypass Switch'
  : values=off
numid=2,iface=MIXER,name='Left Line Mixer Line2R Bypass Volume'
  : values=118
numid=84,iface=MIXER,name='Left Line Mixer PGAL Bypass Switch'
  : values=off
numid=87,iface=MIXER,name='Left Line Mixer PGAR Bypass Switch'
  : values=off
numid=3,iface=MIXER,name='Left Line Mixer PGAR Bypass Volume'
  : values=118
numid=99,iface=MIXER,name='Left Line1L Mux'
  ; type=ENUMERATED,access=rw------,values=1,items=2
  ; Item #0 'single-ended'
  ; Item #1 'differential'
  : values=0
numid=98,iface=MIXER,name='Left Line1R Mux'
  : values=0
numid=97,iface=MIXER,name='Left Line2L Mux'
  : values=0
numid=100,iface=MIXER,name='Left PGA Mixer Line1L Switch'
  : values=on
numid=101,iface=MIXER,name='Left PGA Mixer Line1R Switch'
  : values=on
numid=102,iface=MIXER,name='Left PGA Mixer Line2L Switch'
  : values=off
numid=103,iface=MIXER,name='Left PGA Mixer Mic3L Switch'
  : values=off
numid=104,iface=MIXER,name='Left PGA Mixer Mic3R Switch'
  : values=off
numid=45,iface=MIXER,name='PGA Capture Switch'
  : values=on,on
numid=44,iface=MIXER,name='PGA Capture Volume'
  ; type=INTEGER,access=rw---R--,values=2,min=0,max=119,step=0
  : values=119,119
  | dBscale-min=0.00dB,step=0.50dB,mute=0
numid=40,iface=MIXER,name='Right AGC Attack time'
  ; Item #0 '8ms'
  ; Item #1 '11ms'
  ; Item #2 '16ms'
  ; Item #3 '20ms'
  : values=0
numid=42,iface=MIXER,name='Right AGC Decay time'
  ; Item #0 '100ms'
  ; Item #1 '200ms'
  ; Item #2 '400ms'
  ; Item #3 '500ms'
  : values=0
numid=38,iface=MIXER,name='Right AGC Target level'
  ; Item #0 '-5.5dB'
  ; Item #1 '-8dB'
  ; Item #2 '-10dB'
  ; Item #3 '-12dB'
  ; Item #4 '-14dB'
  ; Item #5 '-17dB'
  ; Item #6 '-20dB'
  ; Item #7 '-24dB'
  : values=0
numid=106,iface=MIXER,name='Right DAC Mux'
  ; Item #0 'DAC_R1'
  ; Item #1 'DAC_R3'
  ; Item #2 'DAC_R2'
  : values=0
numid=13,iface=MIXER,name='Right HP Mixer DACL1 Playback Volume'
  : values=70
numid=61,iface=MIXER,name='Right HP Mixer DACL1 Switch'
  : values=on
numid=64,iface=MIXER,name='Right HP Mixer DACR1 Switch'
  : values=on
numid=59,iface=MIXER,name='Right HP Mixer Line2L Bypass Switch'
  : values=off
numid=11,iface=MIXER,name='Right HP Mixer Line2L Bypass Volume'
  : values=117
numid=62,iface=MIXER,name='Right HP Mixer Line2R Bypass Switch'
  : values=off
numid=60,iface=MIXER,name='Right HP Mixer PGAL Bypass Switch'
  : values=off
numid=12,iface=MIXER,name='Right HP Mixer PGAL Bypass Volume'
  : values=118
numid=63,iface=MIXER,name='Right HP Mixer PGAR Bypass Switch'
  : values=off
numid=19,iface=MIXER,name='Right HPCOM Mixer DACL1 Playback Volume'
  : values=118
numid=49,iface=MIXER,name='Right HPCOM Mixer DACL1 Switch'
  : values=off
numid=52,iface=MIXER,name='Right HPCOM Mixer DACR1 Switch'
  : values=on
numid=47,iface=MIXER,name='Right HPCOM Mixer Line2L Bypass Switch'
  : values=off
numid=17,iface=MIXER,name='Right HPCOM Mixer Line2L Bypass Volume'
  : values=118
numid=50,iface=MIXER,name='Right HPCOM Mixer Line2R Bypass Switch'
  : values=off
numid=48,iface=MIXER,name='Right HPCOM Mixer PGAL Bypass Switch'
  : values=off
numid=18,iface=MIXER,name='Right HPCOM Mixer PGAL Bypass Volume'
  : values=118
numid=51,iface=MIXER,name='Right HPCOM Mixer PGAR Bypass Switch'
  : values=off
numid=105,iface=MIXER,name='Right HPCOM Mux'
  ; type=ENUMERATED,access=rw------,values=1,items=5
  ; Item #0 'differential of HPROUT'
  ; Item #3 'differential of HPLCOM'
  ; Item #4 'external feedback'
  : values=0
numid=7,iface=MIXER,name='Right Line Mixer DACL1 Playback Volume'
  : values=118
numid=79,iface=MIXER,name='Right Line Mixer DACL1 Switch'
  : values=off
numid=82,iface=MIXER,name='Right Line Mixer DACR1 Switch'
  : values=on
numid=77,iface=MIXER,name='Right Line Mixer Line2L Bypass Switch'
  : values=off
numid=5,iface=MIXER,name='Right Line Mixer Line2L Bypass Volume'
  : values=118
numid=80,iface=MIXER,name='Right Line Mixer Line2R Bypass Switch'
  : values=off
numid=78,iface=MIXER,name='Right Line Mixer PGAL Bypass Switch'
  : values=off
numid=6,iface=MIXER,name='Right Line Mixer PGAL Bypass Volume'
  : values=118
numid=81,iface=MIXER,name='Right Line Mixer PGAR Bypass Switch'
  : values=off
numid=91,iface=MIXER,name='Right Line1L Mux'
  : values=0
numid=90,iface=MIXER,name='Right Line1R Mux'
  : values=0
numid=89,iface=MIXER,name='Right Line2R Mux'
  : values=0
numid=93,iface=MIXER,name='Right PGA Mixer Line1L Switch'
  : values=on
numid=92,iface=MIXER,name='Right PGA Mixer Line1R Switch'
  : values=on
numid=94,iface=MIXER,name='Right PGA Mixer Line2R Switch'
  : values=off
numid=95,iface=MIXER,name='Right PGA Mixer Mic3L Switch'
  : values=off
numid=96,iface=MIXER,name='Right PGA Mixer Mic3R Switch'
  : values=off
root@(none):~# amixer -c 0 contents
Booting Linux on physical CPU 0
Linux version 3.6.9 (sdivya@ubuntu) (gcc version 4.7.2 20120701 (prerelease) (c3
CPU: ARMv7 Processor [410fc051] revision 1 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Atmel SAMA5 (Device Tree), model: Atmel SAMA5D34-EK
bootconsole [earlycon0] enabled
Memory policy: ECC disabled, Data cache writeback
AT91: Detected soc type: sama5d3
AT91: Detected soc subtype: sama5d34
AT91: sram at 0x300000 of 0x20000 mapped at 0xfef58000
KDBG: In at91_dt_initialize
Clocks: CPU 528 MHz, master 132 MHz, main 12.000 MHz
KDBG: calling at91_boot_soc_init
KDBG: end of soc init in at91_dt_initialize
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65024
Kernel command line: console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw ro2
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 256MB = 256MB total
Memory: 254012k/254012k available, 8132k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xd0800000 - 0xff000000   ( 744 MB)
    lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
      .text : 0xc0008000 - 0xc052c8fc   (5267 kB)
      .init : 0xc052d000 - 0xc0554c0c   ( 160 kB)
      .data : 0xc0556000 - 0xc0588100   ( 201 kB)
       .bss : 0xc0588124 - 0xc05a1168   ( 101 kB)
NR_IRQS:16 nr_irqs:16 16
sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms
Console: colour dummy device 80x30
Calibrating delay loop... 262.96 BogoMIPS (lpj=1314816)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
Setting up static identity map for 0x20417df0 - 0x20417e48
devtmpfs: initialized
pinctrl core: initialized pinctrl subsystem
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
i2c-core: driver [dummy] registered
AT91: error -22 while looking for mb-rev property, let assume we are using the e
AT91: Power Management (with slow clock mode)
gpio-at91 fffff200.gpio: at address fefff200
gpio-at91 fffff400.gpio: at address fefff400
gpio-at91 fffff600.gpio: at address fefff600
gpio-at91 fffff800.gpio: at address fefff800
gpio-at91 fffffa00.gpio: at address fefffa00
pinctrl-at91 pinctrl.3: initialized AT91 pinctrl driver
bio: create slab <bio-0> at 0
at_hdmac ffffe600.dma-controller: Atmel AHB DMA Controller ( cpy slave ), 8 chas
at_hdmac ffffe800.dma-controller: Atmel AHB DMA Controller ( cpy slave ), 8 chas
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
i2c-core: driver [tca6416-keypad] registered
at91_i2c f0014000.i2c: using dma0chan0 (tx) and dma0chan1 (rx) for DMA transfers
at91_i2c f0014000.i2c: AT91 i2c bus driver.
at91_i2c f0018000.i2c: using dma0chan2 (tx) and dma0chan3 (rx) for DMA transfers
at91_i2c f0018000.i2c: AT91 i2c bus driver.
Linux media interface: v0.10
Linux video capture interface: v2.00
Advanced Linux Sound Architecture Driver Version 1.0.25.
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource tcb_clksrc
NET: Registered protocol family 2
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP: reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
jffs2: version 2.2. (NAND) (SUMMARY)  �© 2001-2006 Red Hat, Inc.
msgmni has been set to 496
NET: Registered protocol family 38
io scheduler noop registered (default)
atmel_hlcdfb atmel_hlcdfb_base: 1500KiB frame buffer at 2f000000 (mapped at d08)
Console: switching to colour frame buffer device 100x30
atmel_hlcdfb atmel_hlcdfb_base: fb0: Atmel LCDC at 0xf0030000 (mapped at d0a1c06
atmel_hlcdfb atmel_hlcdfb_ovl1: 1500KiB frame buffer at 2f200000 (mapped at d0a)
atmel_hlcdfb atmel_hlcdfb_ovl1: fb1: Atmel LCDC at 0xf0030140 (mapped at d0b9a16
atmel_hlcdfb atmel_hlcdfb_ovl2: 1500KiB frame buffer at 2ec00000 (mapped at d0b)
atmel_hlcdfb atmel_hlcdfb_ovl2: fb2: Atmel LCDC at 0xf0030240 (mapped at d0d1826
f0020000.serial: ttyS2 at MMIO 0xf0020000 (irq = 24) is a ATMEL_SERIAL
ffffee00.serial: ttyS0 at MMIO 0xffffee00 (irq = 36) is a ATMEL_SERIAL
console [ttyS0] enabled, bootconsole disabled
brd: module loaded
loop: module loaded
ssc f0008000.ssc: Atmel SSC device at 0xd0d20000 (irq 19)
at24 1-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
i2c-core: driver [at24] registered
atmel_nand 60000000.nand: Using NFC
atmel_nand: Use On Flash BBT
atmel_nand 60000000.nand: Using dma0chan4 for DMA transfers.
atmel_nand 60000000.nand: Time out to wait status ready!
No NAND device found
atmel_spi f0004000.spi: Using dma0chan4 (tx) and  dma0chan5 (rx) for DMA transfs
atmel_spi f0004000.spi: Atmel SPI Controller at 0xf0004000 (irq 18)
atmel_spi f0004000.spi: master is unqueued, this is deprecated
m25p80 spi32766.0: found mr25h256, expected at25df321a
m25p80 spi32766.0: mr25h256 (32 Kbytes)
CAN device driver interface
at91_can f000c000.can: device registered (reg_base=d0d1e000, irq=20)
at91_can f8010000.can: device registered (reg_base=d0d26000, irq=28)
macb f0028000.ethernet: (unregistered net_device): invalid hw address, using ram
libphy: MACB_mii_bus: probed
macb f0028000.ethernet: eth0: Cadence GEM at 0xf0028000 irq 25 (ea:c6:ac:59:d4:)
macb f0028000.ethernet: eth0: attached PHY driver [Generic PHY] (mii_bus:phy_ad)
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
atmel-ehci 700000.ehci: Atmel EHCI UHP HS
atmel-ehci 700000.ehci: new USB bus registered, assigned bus number 1
atmel-ehci 700000.ehci: irq 44, io mem 0x00700000
atmel-ehci 700000.ehci: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: Atmel EHCI UHP HS
usb usb1: Manufacturer: Linux 3.6.9 ehci_hcd
usb usb1: SerialNumber: 700000.ehci
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 3 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
at91_ohci 600000.ohci: AT91 OHCI
at91_ohci 600000.ohci: new USB bus registered, assigned bus number 2
at91_ohci 600000.ohci: irq 44, io mem 0x00600000
usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: AT91 OHCI
usb usb2: Manufacturer: Linux 3.6.9 ohci_hcd
usb usb2: SerialNumber: at91
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 3 ports detected
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver usbserial
usbserial: USB Serial Driver core
atmel_usba_udc 500000.gadget: MMIO registers at 0xf8030000 mapped at d0d30000
atmel_usba_udc 500000.gadget: FIFO at 0x00500000 mapped at d2400000
 gadget: using random self ethernet address
 gadget: using random host ethernet address
usb0: MAC 2e:b2:fc:3e:ca:a3
usb0: HOST MAC de:86:60:47:ed:4e
 gadget: Ethernet Gadget, version: Memorial Day 2008
 gadget: g_ether ready
i2c-core: driver [atmel_mxt_ts] registered
atmel_tsadcc f8018000.tsadcc: Master clock is set at: 66000000 Hz
atmel_tsadcc f8018000.tsadcc: Prescaler is set at: 109
input: atmel touch screen controller as /devices/ahb.0/apb.1/f8018000.tsadcc/in0
at91_rtc fffffeb0.rtc: rtc core: registered fffffeb0.rtc as rtc0
AT91 Real Time Clock driver.
i2c /dev entries driver
i2c i2c-0: Added multiplexed i2c bus 2
i2c i2c-0: Added multiplexed i2c bus 3
i2c i2c-0: Added multiplexed i2c bus 4
i2c i2c-0: Added multiplexed i2c bus 5
i2c i2c-0: Added multiplexed i2c bus 6
i2c i2c-0: Added multiplexed i2c bus 7
i2c i2c-0: Added multiplexed i2c bus 8
i2c i2c-0: Added multiplexed i2c bus 9
pca954x 0-0070: registered 8 multiplexed busses for I2C switch pca9548
KDBG: pca954x is probed
KDBG: Audio is enabled by writing 20
KDBG: Value read from bus after enabling audio is 20
i2c-core: driver [pca954x] registered
i2c-core: driver [ov2640] registered
at91sam9x5-video f0030340.lcdheo1: video device registered @ 0xd0d2e340, irq = 6
gspca_main: v2.14.0 registered
usbcore: registered new interface driver uvcvideo
USB Video Class driver (1.1.1)
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
i2c-core: driver [tlv320aic3x] registered
sama5d3ek-audio sound.5: setting pck0 to 32768Hz
usb 1-3: new high-speed USB device number 2 using atmel-ehci
sama5d3ek-audio sound.5:  tlv320aic3x-hifi <-> f0008000.ssc mapping ok
TCP: cubic registered
NET: Registered protocol family 10
sit: IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
lib80211: common routines for IEEE802.11 drivers
VFP support v0.3: implementor 41 architecture 2 part 30 variant 5 rev 1
at91_rtc fffffeb0.rtc: setting system clock to 2007-01-01 00:37:57 UTC (1167611)
atmel_mci f0000000.mmc: version: 0x505
atmel_mci f0000000.mmc: using dma0chan6 for DMA transfers
atmel_mci f0000000.mmc: Atmel MCI controller at 0xf0000000 irq 17, 1 slots
atmel_mci f8000000.mmc: version: 0x505
atmel_mci f8000000.mmc: using dma1chan0 for DMA transfers
usb 1-3: New USB device found, idVendor=0424, idProduct=2513
usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
atmel_mci f8000000.mmc: Atmel MCI controller at 0xf8000000 irq 27, 1 slots
atmel_aes f8038000.aes: version: 0x135
hub 1-3:1.0: USB hub found
hub 1-3:1.0: 3 ports detected
atmel_aes f8038000.aes: Atmel AES
atmel_tdes f803c000.tdes: version: 0x701
mmc0: host does not support reading read-only switch. assuming write-enable.
mmc0: new high speed SDHC card at address aaaa
mmcblk0: mmc0:aaaa SU04G 3.69 GiB
atmel_tdes f803c000.tdes: Atmel DES/TDES
atmel_sha f8034000.sha: version: 0x410
 mmcblk0: p1 p2
atmel_sha f8034000.sha: Atmel SHA1/SHA256
ALSA device list:
  #0: tlv320aic3x @ SAMA5D3
Thanks in advance,
Dhiv
