Dear Sir,
In the datasheet TPA3130D2 page 5, it is said for TPA3130D2 BTL mode the minimum load impedance is 5.6 OHM, for TPA3118D2 is 3.2 OHM.
I wonder what is the difference between TPA3130D2 and TPA3118D2 can determine the minimum load impedance.
If I connect a TPA3130D2 with two 4 OHM loads , it will work OK or NG in theory?
I've applied TPA3130 samples and it will arrive 2 weeks later, I can't do a full test now.
Thanks.
