Other Parts Discussed in Thread: LM4675, LMC6035
I'm debugging an audio quality issue in a design using the LM4675. The LM4675 is implemented (almost!) as per Figure 28 (single-ended input) in the datasheet (rev 1.3).
Component Values...
Ri = 75k
Ci = 3.3nF
Cs = 4.7uF + 22pF
The notable difference from Figure 28 is that the AC ground is tied to IN- (not IN+). Correspondingly, the single-ended input is tied to IN+ (not IN-).
Could this be the cause of pop and click noises we observe? This design is implemented in very small mechanics with limited options to re-route the signals through rework.
Thanks!
