Does the PGA2311 require that the VA+ power pin comes up before VD+, or just that VD+ to VA+ is separated by less that +/-0.3V? Can SCR latch up still occur if VA+ pin is shorted to VD+?
I'm seeing latent failures where the PGA2311 VA- rail over time collapses from -5V to around -3.5V (the PGA2311 is the only load on the -5V regulator).
