My customer is now trying to evaluate PCM5102A on PCM510xEVM-U without CodecControl software and any of digital block (like USB, SRC and so on).
(PCM5102A already mounted on board instead of PCM5102)
Here I tried to summarize what we need to change EVM setting, can you please check below and let me know, if I miss something?
- Remove all of jumpers of W3 (This is to disconnect PCM5102A side from digital side.)
- Use TP9 through TP15 to access to input of PCM5102A
- Input signals can be applied from TP10(SCK), TP11(BCK), TP12(DIN) and TP13(LRCK).
- Some function select signal also can be applied from TP9(FLT), TP14(FMT) and TP15(XSMT).
- PCM5102AEVM-U still can be powered by USB connector, but if necessary, 3.3V can be applied from TP20 after removing W4 jumper.
Thank for your support in advance.
Ken
