I will replace in the sw startup/shutdown the " SPK_SD Pin" by a " SPK_SD" bit
Other Parts Discussed in Thread: TAS5760LD
On the same time: I wil connect the  " SPK_SD Pin" on a high continue, same as  the "FAULT pin"
Is this a correct statement to avoid plops during the startup/down routine?
