LM4675 EXPOSED-DAP
I want to use the LM4675SD/NOPB : can I the link the Exposed Pad of the 8-Pin WSON  package to the GND?
  • Hi, Frederic,
    Yes, you should tie it to ground. And, use as much copper area as possible on the PCB to get the best heat sinking from your board. Put vias from the top to bottom of the PCB, and flood the bottom of the PCB with ground copper.
    -d2
