Hello TI:
I had a question on the PCM CODEC. The datasheet has figures 36 and 38 that are very identical except 36 uses a voltage regulator. I am confused.
How can I drive voltage into the pin VCCCI which also has an internally generated voltage? One option uses external supply and the other internal but there is no strap or setting which to use and which not to. I would like to understand this.
