Does TLV320AIC23B "resist" if it gets only MCLK and not LRCK/BCK during some time ?
Other Parts Discussed in Thread: TLV320AIC23B
Hello everybody
I am working on an application using an audio codec, but this application has a particularity. During some periods of time, the DSP may not generate I2S signals BCK and LRCK. Only the MCK signal will remain available.
Problem: my DSP does not support I2S slave mode, it must be master (so the TLV320 can not be used as a clock source).
During our tests, we found two chips which do not resist at all to these specific conditions (they are destroyed if they do not receive the three clocks....). I would like to know if some of you know if the TLV320AIC23B is able to support this ?
Thank you by advance for your help
Benoit
