According to the datasheet, the maximum input clock frequency is 25MHz. Would it be possible to use the part with a slightly higher BCLK (28.224MHz) while keeping WCLK within the Fs limit (e.g. 352,800kHz)? If it turns out to work (for a digital sine wave input you see the corresponding analog sine wave output), could the faster BCLK degrade the audio performance in any way?
Thank you for any help you can provide.
Peter Kurz
