TAS5558 query
Other Parts Discussed in Thread: TAS5558, TAS5614LA, TAS5632
Hi Guys
i am planning to use TAS5558EVM  and TAS5558 IC for one of our projects  . Need to clarify following points.
1. What is the PWM modulated output frequency? is it fixed at 384khz or can be changed by varying SW Settings?
2. How to connect PWM channel output connection to Single ended  audio amplifier configuration?
3. Does TAS 5558 supported Single ended audio amplifier module, IC?
4. Can TAS 5558 be connected to single ended mode need reference schematic of the same.
5. we need TAS 5558 PWM Output Demodulation circuit for SE mode.
we are using this for Visual Line communication project. This will be used as analog to PWM converter. This PWM data can be transferred using LED's to the Speaker so as to avoid usage of RF link.
pls help me out with your suggestion this is very urgent as i need to finalize my design.
regards,
syed hamad
