Other Parts Discussed in Thread: CC8530
We have some dificulty to use the host mode with the CC8530.
Is there a specific algorithm with a timing to respect to be sure that the connection between host and slave is established and correct ?
What we observe here is that some minor changes in the control software gives us goog or bad results. We haven't found logic between the differents results to validate a solution.
The same software applicated on two similar cards can give a good working solution or not.
With these cards, when the link is estabished, there is no problem and the transmission is always good. That's for the audio link and the DSC link.
Our problem is to establish the connection. With the first board the connection is good at each attempt. With the second board and the same software, we do not succeed to take the line and need to retry to have a good connection.
We think we can have timing issue but we don't find it. We haven't found anything in the data sheet.
Thank for your help
Best regards
Bernard
