NEED INFORMATION- LM1875T/LB02
Hi Can you please provide the following information for the LM1875T/LB02  Part ?
1. Junction Temperature Max (Tj Max)
 2. Typical Power dissipation (Pd typ)
3. Maximum Power dissipation (Pd max)
4. Thermal Resistance Junction to Ambient (Theta JA
5. Thermal Resistance Junction to Board (Theta JB)
6. Thermal Resistance Junction to Case (Theta JC)
7. Weight
  • Hi, Jayakumara,
    Unfortunately, we do not have this data for this device. All the data we have is published in the data sheet.
    -d2
  • HI Jayakumara-san,
    I'll make some comments on your question.
    LM1875T/LB02 part in NS pkg is the same pkg as TI TA05B pkg.
    1)  Tjmax is 150 deg C
    2) Pd typ , 3) Pd max is depending on power supply voltage and load resistor value. Please reffere to the datasheet pg 8 which is shown about how to calcurate Pd max .
    4) Θja=73deg C see datasheet pg 2
    5) Θjb --- sorry we don't have the data
    6) Θjc=3 deg C
    7) Weight: Sorry we don't have the data
    Best regards
    T NAOKAWA
