Is it possible to use the PCM2706 circuit to read MP3 or WAV files from a stand alone USB Flash drive and output them as left and right analogue audio?
Hi, Geoff,
It seems like this is a recurring theme that comes up from time to time here in the community.
Any members want to share how they have accomplished what Geoff is trying to do?
-d2
Hello Don
Thank you for your response.
We were hoping that an application engineer at TI itself would be able to answer this fundamental question about a TI product. Is this possible?
Geoff Mellor
The PCM2706 is a USB audio codec without on-chip processing. It requires a USB host (running a USB class-audio compatible SW stack) as a master (for configuration) and as the audio source/sink.
Hi, Geoff,
This topic has been addressed several times previously. Please see these threads:
http://e2e.ti.com/support/data_converters/audio_converters/f/64/t/202197.aspx
http://e2e.ti.com/support/data_converters/audio_converters/f/64/p/573/2164.aspx#2164
http://e2e.ti.com/support/data_converters/audio_converters/f/64/t/2469.aspx
http://e2e.ti.com/support/data_converters/audio_converters/f/64/p/122792/437988.aspx#437988
So, as you can see, TI does not have a good solution for this in a simple stand-alone IC.
I was hoping that someone in the community would chime in and point you in the direction of an IC that does what you want. I have seen many customers in China using ICs to do essentially exactly what you want, but I don't know the manufacturer or part number of that chip.
-d2
