I am designing my schematic to use the TPA3132DT part, but in reviewing the datasheet, I am starting to lose confidence in this solution - can you help answer these questions:
- the pin description for GVDD says nothing but a 1uF cap should be connected to it, but the schematics show resistor dividers attached.
- the recommended supply for AVCC is shown from 4.5V to 26V, but the DC electrical characteristics table shows GVDD to have a minimum voltage of 6.4V. The block diagram shows that GVDD is derived from an LDO supplied by AVCC. What should the AVCC voltage be?
- the typical application diagram doesn't even show AVCC connected.
Thanks for help in clarifying these items.
Dave
