Other Parts Discussed in Thread: TLV320DAC3100
HI
I would like to check with you on the difference between TLV320DAC3100 and TLV320DAC3100 -Q1.
ON the data sheet, there appears to be no difference, Even the EVB are the same
Except in the "-Q1" data sheet section 5.2.1.1 Power-Supply Sequence, it was spelt out the recommendation for power sequencing. Would we need to apply this power up sequence to the none "-Q1" as well?
The EVB does not appear to take care of power sequence
Hope to have your clarification
Ivan
