Other Parts Discussed in Thread: TAS5630
I have just purchased a 2 chip tda7294 stereo amplifier board that only required a heatsink and a transformer.
After making the additions, I tested the amp out on a pair of unused speakers in my basement and all was good. I then brought the amp upstairs and connected it to my usual equipment and it sounded great.
After a while I decided to to check the temperature of the heatsink and when I touched it there was a flash and a pop and a cloud of smoke from one of the 7294 chips. On looking at the burnt chip I noticed that the mica plate was not parallel to the chip which meant there was a gap under one corner of the chip.
It is very cold here in the winter and there is much static in the house and shocks are common when touching a metal radiator or water tap and even the cat!
Is it possible possible that a static charge caused a spark to jump across the small gap left between the chip and the heatsink when I touched it and caused the chip to blow?
Thanks. Terry
PS, I have been using a little tda7297 board for several months and I cannot believe how good it sounds.
